omg i could kiss u ecu man.
mwa ewwwww.mwa ewwww...mwa mmmm pizza...mwa ewwww
ill take the zero
lol
thats fues only does PGMFI
lol yeah just read ur post in the steering wheel thread about resetting srs, posted one last Q lol...thanx so much for all this mate
just did it again, fuel economy started dieing on me...
so u remove both fuses at same time (15amp ~ 10 mins, and 7.5amp ~ 30 secs) or just the 7.5amp fuse 4 30 secs. then let the car idle 4 10 mins. theres been so many opinions on this im confused wat to do ><
be on the safe side, i just take both out for 10 mins
then idle for 10 mins, then drive how you most likely do, but occassionally going through the revs so it can 'learn'
so if i have an aftermarket alarm should i do it..!?!
if i pull out both fuses will i lose all my settings on my headunit etc..!?!?
yes you lose your settings on the head unit.
lol.
that's why i ain't doin it.
cbf going through em again.
lol.
I tried to do this on my EF this morning...
I unplugged the ECU fuse under the bonnet and the Hazard relay under the dash for 2 mins, but when the fuses are unplugged i tried to press the hazard light and indicators still blinks :confused:
Is that right??
You dont have to remove the ecu fuse,just make sure the ignition is turned off.
You have to remove the hazard FUSE for the ED-EF for 10-20 sec located in the same place as the ecu fuse,under the hood.
Quote:
Originally Posted by CRXer
:thumbsup:
it only takes 3mins to reset not 10.
