No part of this DIY is to be reproduced with out acknowledgment of the site and author it came from, ie me and ozhonda.com. Do not rip parts off and claim them as your own.
PO2H "Primary Oxygen Sensor Heater". The PO2H is commonly located on the back of the dump pipe under the car between the cat and the sump. The PO2H helps heat up the Oxygen Sensor to operating temp at start up to get the O2 sensor working sooner. The Heater is a wire wound heater element.
Aim:
Diagnose code 41.
Required:
Basic Testing
- Digital Multi Meter
- paper clip
Symptoms
A faulty PO2H will trigger code 41. The Engine light will come on and code 41 will be registered in ECU memory. An open circuit in the PO2H is a common cause for code 41.
Basic Test
- Perform a Visual inspection and make sure the PO2H is connected.
PO2H Pin out Picture
wire side of connector back probing
HO2 wire colour
1 = wht
2 = grn or gry
3 = blk
4 = blk
**** Voltage Test ****
Set your multi meter to DC Volts ( 20v scale )
Step 1 ( Reference Voltage test )
Check the PO2H for its Reference Voltage from the ECU. Connect the Black Lead from your multi meter to the chassis for a good ground. Back probe* the PO2H with the Red lead to Pin 3 of the PO2H while the sensor is connected.
KOER* you must get 12v
If you get 12v proceed to step 2,
if you do not get 12v, repair open or short circuit to ECU from Pin 3 of PO2H to the below ECU Pin ( also see continuity test below )
OBDO = A15
OBDI = A25
OBDIIa = A11
OBDIIb = B1
If you do not get 12v from the ECU pin above, replace the ECU.
STEP 2
Check the PO2H Signal. Connect the Red Lead from your multi meter to the battery Positive terminal. Back probe* the PO2H with the black lead to Pin 4 of the PO2H while the sensor is connected.
KOER* you should get 12v.
also check the PO2H signal at the ECU end at the following pin bellow
OBDO = n/a
OBDI = A6; note 1994 - 1995 Accord A11
OBDIIa = A6
OBDIIb = C1
If You do not get 12v replace the ECU
***** Its is always best to check sensor outputs at the sensor side *****
**** Continuity Test ****
Set your multi meter to continuity. This setting is mostly a picture of a sound .))) when you touch the Red and Black leads together on your meter it should beep.
STEP 1
make sure the Ignition is off and unplug the PO2H Connector and the ECU Connectors for this test
Continuity test between PO2H Pin 3 and ECU, Connect your Red multi meter lead on the PO2H Pin 3, Back probe* the Black multi meter lead on the ECU Pin below that suits your car.
OBDO = n/a
OBDI = A25
OBDIIa = A11
OBDIIb = B1
your multi meter should beep and read short or 000.0ohms. Place the black multi meter lead on a good ground source. You should not get beeping; this is testing for short to ground.
STEP 2
Continuity test between PO2H Pin 4 and ECU, Connect your Red multi meter lead on the PO2H Pin 4, Back probe* the Black multi meter lead on the ECU Pin below that suits your car.
OBDO = n/a
OBDIIa = A6
OBDIIb = C1
your multi meter should beep and read short or 000.0ohms. Place the black multi meter lead on a good ground source. You should not get beeping, this is testing for short to ground.
If any of your continuity tests fail between the PO2H and ECU, repair the OPEN in the wire between the PO2H and ECU that failed.
If any of your continuity tests fail between the PO2H and ground, Find the short circuit and repair it. look for squashed wires, or for damage to any part of the PGMFI loom.
**** Resistance Test **** Set the multi meter to ohms ( 1K scale )
Unplug the PO2H, connect your Red multi meter lead to Pin 3 of the PO2H. Connect your Black multi meter lead to Pin 4 of the PO2H.
the resistance should be between 10 to 40 ohms
reset the ECU and road test the car.
* Notes
KOEO = Key On Engine Off
KOER = Key On Engine Running
Back probe the sensor, use a paperclip and push it into the connector then touch/clip your multi meter lead to the paper clip
